Want to plug into today's most advanced USB peripherals? With speeds up to 40 times faster than USB 1.1, the StarTech.com's PCI330USB2 is your ticket to high-speed action. This card lets you connect up to three USB 2.0 peripherals and enjoy fast data transfer rates of up to 480 Mbits/sec. Plus, backwards compatibility with USB 1.1 means you can continue using your older USB peripherals. The PCI330USB2 is built with an NEC chipset for increased reliability and compatibility with USB devices. Easy plug and play makes installation a breeze, and hot swapping capabilities guarantee convenient, hassle-free connections without rebooting.
- StarTech.com 4 Port PCI High Speed USB 2.0 Adapter Card - USB adapter - PCI - 4 ports
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Bus Voltage
- Universal (3.3 V & 5.0 V)
- 2 cm x 12.7 cm x 12 cm
- 45 g
- Ports Qty
- 4 ports
- Data Link Protocol
- USB, USB 2.0
- Data Transfer Rate
- 480 Mbps
- System Requirements
- Apple MacOS X, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
- Designed For
- P/N: ICUSBAUDIO, ICUSBAUDIO7D, ICUSBAUDIOB
- USB adapter - 4 ports
- Form Factor
- Plug-in card
- PCI
- Bus Voltage
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
- 3 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
- Compatible Slots
- 1 x PCI
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 2 cm
- 12.7 cm
- 12 cm
- 45 g
- Designed For
