Allows an HDMI connection to be mounted on a secure and easily accessible panel. The HDMIPNLFM3 3ft Standard HDMI Cable for Panel Mount features an HDMI male connector on one end, and an HDMI panel mount (female) molded connector on the other, providing a well-secured, easy to access HDMI connection on any machine port or faceplate.
- StarTech.com 3ft HDMI Female to Male Adapter, 4K High Speed Panel Mount HDMI Cable, 4K 30Hz UHD HDMI, 10.2 Gbps Bandwdith, 4K HDMI 1.4 Video, HDCP 1.4, HDMI Female to HDMI Male Cable - HDMI Panel Mount Connector - HDMI cable - 91 cm
- Cable
- HDMI cable
- American Wire Gauge (AWG)
- 28
- Length
- 91 cm
- Black
- Connector
- HDMI - female
- Connector (Second End)
- HDMI - male
- Molded
- Limited lifetime warranty
- Designed For
- P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB
- Cable Type
- HDMI cable molded
- 28
- Jacket Material
- PVC
- Length
- 91 cm
- Black
- Connector
- 19 pin HDMI Type A - female
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.93 |
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £5.49 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £6.60 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.49 |
StarTech.com HDMI Coupler / Gender Changer - F/F | In Stock | £8.43 |
StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip | In Stock | £11.52 |
