StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black
Quicklinx: 95PYWS00 Mfr#: DP2DVIMM3BS
Length: 91.5cm
£21.79 ex VAT
£26.14 inc VAT
Eliminate excess cable clutter with a short 3ft DisplayPort to DVI active adapter. The DP2DVIMM3BS 3ft active DisplayPort to DVI converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a nearby DVI monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
For guaranteed compatibility with virtually any DisplayPort output the active DisplayPort to DVI adapter supports multimode (DP++) as well as single-mode DisplayPort signals. Unlike passive adapters, this ensures the DP2DVIMM3BS can be used with graphics cards that are not capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
Plus, because the converter cable supports video resolutions up to 2560x1600 you can convert a DisplayPort video source to DVI without sacrificing video quality.
  • DisplayPort to DVI cable
    3ft (0.9m) DisplayPort 1.2 (HBR2) to DVI-D single-link cable connects a DVI display, monitor or projector | 1920x1200/1080p 60Hz or 4K 30Hz (HDMI clock rate); EDID pass-through ensures compatibility between source & display.
  • Compatibility
    Active video converter supports DP (single mode) or DP++ (multi-mode) source including workstations, desktops (AMD/NVIDIA), laptops, small form factor computers & docking stations.
  • Integrated display cable
    DisplayPort to DVI adapter cable has slim & flexible design w/adapter chip built into DVI connector reducing clutter & providing a tidy install in the office, boardroom or home office.
  • Latching DisplayPort & screw locking DVI
    Latching DP connector ensures a solid host connection, and chip built into DVI connector minimizes signal loss | Supports DVI screw locking cable to prevent cable from coming loose or accidental disconnection.
  • Easy to use
    With no software or drivers required, the DP to DVI cable/cord works with any OS including Windows, Ubuntu and macOS; DisplayPort male to DVI male cable.
StarTech.com 3 foot DisplayPort to DVI Active Adapter Converter Cable - 3 ft (0.9m) Active DP to DVI M/M Cable for PC - 1920x1200 - Black (DP2DVIMM3BS) - DisplayPort cable - 91.5 cm
DisplayPort cable
Active cable (signal regeneration)
Length
91.5 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
P/N: MST30C2DPPD, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
DisplayPort cable
Length
91.5 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
95PY StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £31.28
95PY StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £23.82
95PY StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
95PY StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £16.91
95PY StarTech.com DisplayPort to DVI Active Adapter In Stock £22.72
95PY StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £65.80
95PY StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £21.79
95PY StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black In Stock £24.24
95PY StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £23.85
95PY StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black In Stock £21.46
95PY StarTech.com 3ft DP to DVI Converter Cable In Stock £16.71
Length: 91.5cm
