Connect a 4-position headset with audio and microphone input to your desktop or laptop computer.
The MUYHSFMM 4-Position 3.5mm to dual 3.5mm Headset Splitter Adapter features one 3.5mm Female and two 3.5mm Male connectors, enabling you to connect a 4-position headset with Audio and microphone input to your PC or Laptop.
This 3.5mm Headset Splitter Adapter connects into both the audio and mic ports on your desktop or laptop computer, providing a single (4-Position) female connector - a perfect solution for online gaming or use with VOIP applications (Skype, chat programs).
Featuring a compact, yet sturdy design, the headset splitter delivers the perfect solution for applications that require portability, and takes up very little space in your laptop bag.
- StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M - 3.5mm headset Adapter Cable (MUYHSFMM) - headset splitter
- Cable
- Headset splitter
- American Wire Gauge (AWG)
- 30
- Black
- Connector
- 2 x mini-phone stereo 3.5 mm - male
- Connector (Second End)
- 4-pole mini jack - female
- Limited lifetime warranty
- Designed For
- P/N: MUHSMF2M, PEXSOUND7CH
- Cable Type
- Headset splitter
- 30
- Jacket Material
- PVC
- Plated Connector
- Nickel
- Black
- Connector
- Mini-phone 3.5 mm 4-pole - female
- RoHS
- Limited warranty - lifetime
- Designed For
StarTech.com 6in Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £3.53 |
StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M | In Stock | £7.65 |
StarTech.com 3.5mm 3 Pin Headset Splitter | In Stock | £4.88 |
StarTech.com Slim Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £4.69 |
StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £5.89 |
StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £5.47 |
StarTech.com 4 Position to 2x 3 Pin 3.5mm Headset Splitter Adapter - White | In Stock | £4.69 |
