StarTech.com 2Port PCIe SATA Controller Car
Quicklinx: 5FF5WS00 Mfr#: PEXESATA2I
Add an internal SATA port and an external SATA (eSATA) port to your desktop computer through a PCI Express expansion slot. This PCI Express SATA Controller Card allows you to turn a PCI Express (1x) slot into one internal SATA and one external SATA (eSATA) connection. Supporting SATA 300 (SATA II) hard drives and data transfer rates of up to 3Gbps, this controller card is the perfect solution if you need an extra SATA port or want to externalize your storage.
The controller card is designed based on a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for your external storage needs. Plus, PEXESATA2I features Port Multiplier support with command based switching for connecting multiple external hard drives to host PC or Mac Desktop through one eSATA connection.
StarTech.com 1 Port eSATA + 1 Port SATA PCI Express SATA Controller Card - storage controller (RAID) - SATA 3Gb/s / eSATA 3Gb/s - PCIe x1
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe x1
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive, disk array (RAID)
Channel Qty
2
Max Storage Devices Qty
2
RAID Level
JBOD
Microsoft Windows Vista / 2000 / XP
12 cm x 10.2 cm x 2 cm
44 g
P/N: S3540BU33E
Host Bus
PCIe x1
Storage Controller
Data Transfer Rate
3 Gbit/s
Supported Devices
Channel Qty
2
2
RAID Level
JBOD
JMicron JMB363
1 x SATA 3Gb/s - eSATA (external) , 1 x SATA 3Gb/s - SATA (internal)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
12 cm
10.2 cm
2 cm
44 g
P/N: S3540BU33E
