Clutter-free installation
While this white adapter looks great next to computers that match the look and feel of laptops like your MacBook or HP Envy, it works with any USB-C computer that supports HDMI. At 2 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy and professional installation. -
Astonishing picture quality
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60 Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60 Hz implementation.
- StarTech.com 6ft (2m) USB C to HDMI Cable, 4K 60Hz USB Type C to HDMI 2.0 Video Adapter Cable, Thunderbolt 3 Compatible, Laptop to HDMI Monitor/Display, DP 1.2 Alt Mode HBR2 Cable, White - 4K USB-C Video Cable (CDP2HD2MWNL) - external video adapter - VL100 - white
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- VL100
- Max Resolution
- 3840 x 2160
- HDMI (male connector)
- 2.2 cm 1.4 cm
- Length
- 2 m
- Enclosure Colour
- White
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Bus Type
- USB-C
- Graphics Engine
- VL100
- Max Resolution
- 3840 x 2160 at 60 Hz
- HD/4k Ready, 7.1 channel surround sound ready, Thunderbolt 3 compatible
- FCC, RoHS, WEEE
- 2.2 cm
- 1.4 cm
- Length
- 2 m
- 80 g
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 5 - 90% (non-condensing)
- Designed For
- P/N: TB4CDOCK
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £32.27 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £31.44 |
StarTech.com 2m USB C to HDMI Cable - Black | In Stock | £27.71 |
StarTech.com 1m USB C to HDMI Cable - Black | In Stock | £27.65 |
StarTech.com 3m USB C to HDMI Cable - Black | In Stock | £28.89 |
StarTech.com 1m USB C to HDMI Cable - White | In Stock | £24.31 |
StarTech.com 3m USB-C to DVI Cable - Black | In Stock | £25.34 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.81 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.25 |
