StarTech.com 2m (6 ft) Long Left Angle Apple 30-pin Dock Connector to USB Cable - Stepped Connector
Quicklinx: 8BM3WS00 Mfr#: USB2ADC2ML
Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. The USB2ADC2ML USB cable for iPhone, iPod and iPad (2m) features a left-angled Apple (30-pin) Dock Connector which positions the cable in such a way that it allows you to easily access your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 2m Right Angle Apple 30-pin Dock Connector to USB Cable (USB2ADC2MR), which provides the same convenience as this left-angled cable, but allows you to connect to your iPhone, iPod or iPad from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 2m Left Angle Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 2 m
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
24
Length
2 m
White
Connector
USB - male
Connector (Second End)
Apple Dock - male
Angled connector
Cable Type
Charging / data cable angled connector
Shielded
24
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
White
Connector
4 pin USB Type A - male
Apple Dock connector - male
RoHS, MFI
Limited warranty - lifetime
