StarTech.com 2m Coax High Resolution Monitor VGA Cable with Audio HD15 M/M
Quicklinx: 839NWS00 Mfr#: MXTHQMM2MA
Length: 2m
£15.60 ex VAT
£18.72 inc VAT
Make VGA video and audio connections using a single, high quality cable. The MXTHQMM2MA 2-meter High Resolution VGA Cable with Audio is a high quality SVGA cable designed to provide the highest video quality possible through VGA - a single cable solution for connecting both video between a VGA video card and monitor, and audio connections between a sound card and external audio device.
StarTech.com's high resolution VGA cable with audio features high quality male-to-male coaxial VGA cable, and is designed to eliminate picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 2m Coax High Resolution Monitor VGA Video Cable with Audio - VGA cable - 2 m
VGA cable
Double shielded twisted pair triple coaxial
Molded, thumbscrews, strain relief, ferrite core
Length
2 m
Connectors
HD-15 (VGA) - male , Mini-phone stereo 3.5 mm - male
Connectors (Second End)
UL 2919, RoHS, NEC-CMG
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
2 m
Connectors
15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
839N StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.07
839N StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £7.06
839N StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £7.03
Length: 2m
