Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM25FL 25-foot Flat High Speed HDMI Cable with Ethernet supports Ethernet data interconnectivity with compatible HDMI devices and features a flat-shaft design that makes it suitable for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
- StarTech.com 25 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - Flat HDMI Cable (HDMIMM25FL) - HDMI cable with Ethernet - 7.6 m
- Cable
- American Wire Gauge (AWG)
- 24
- Length
- 7.6 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Cable Type
- 24
- Jacket Material
- PVC
- Length
- 7.6 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
