Your basket is empty
StarTech.com 25' Cat5e Patch Cable Blue
Quicklinx: 4001WS00 Mfr#: M45PATCH25BL
Length: 7.6m
1 in stock
£4.40 ex VAT
£5.28 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT25BL Cat5e Patch Cable (25 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com Molded Cat 5e UTP Patch Cable - patch cable - 7.6 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wire(s)
Moulded
Length
7.6 m
Connector(s)
1 x RJ-45 - male
Connector(s) (Other Side)
1 x RJ-45 - male
Blue
P/N: ST121HDMR50, PEX100S, MCM110ST, PS2UTPEXT, USB6N1DOCKGB, USB6N1DOCK, BR4100DC
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wire(s)
Pairs per Cable
4 pair(s)
Moulded
Length
7.6 m
Blue
Connector(s)
1 x RJ-45 - male
1 x RJ-45 - male
StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card, 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, HDMI over Cat 5 Video Extender - Receiver, PS/2 Keyboard and Mouse Extender over Cat 5 , StarTech.com Converge A/V HDMI Over CAT5 / UTP Receiver
Length: 7.6m
Colour: Blue
Price Range Ex VAT: 0 - 50
