StarTech.com 21U Open Frame Equipment Rack
Quicklinx: GTBQWS00 Mfr#: RACK-21U-20-WALL-OA
Hurry, only 2 left in stock!
£180.22 ex VAT
£216.26 inc VAT
The RACK-21U-20-WALL-OA 21U Open Frame Wall Mount Equipment Rack with Adjustable Depth is a high-quality, sturdy relay rack solution that is easy to assemble and install into any environment.
  • Sturdy Construction & Easy Installation
    The open rack features an adjustable depth ranging from 12-20 inches to accommodate larger data, network, and telecommunications devices. With a maximum depth of 20 inches, this rack allows for mounting of shelves and other accessories with enough clearance at the back for cable management. The open-frame design help to keep your equipment cool and easily accessible from different angles. The wall mounting holes are positioned 12 and 16 inches apart (center to center) providing a convenient and effecting anchoring, making it suitable for mounting on virtually any wall surface or construction framework.
  • Includes Hardware
    This 21U rack includes M6 square cage nuts and M6 screws to save you the hassle of sourcing separate mounting hardware for your equipment. This rack can be mounted to the wall in a server room, data closet, or office expanding your valuable floor space. The RACK-21U-20-WALL-OA is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 21U 19" Wall Mount Network Rack, Adjustable Depth 12-20" 2 Post Open Frame Server Room Rack for AV/Data/ IT Communication/Computer Equipment/Switch with Cage Nuts & Screws - 21U Adjustable Rack - rack - 21U
Rack
Rack Type
Open frame - 2-post
Placing / Mounting
Wall mountable
Package Content
2 front horizontal brackets, 2 rear horizontal brackets, 16 M5 x 12mm screws, 2 vertical brackets, 24 M8 x 16mm bolts, 24 #8 flat washers, 84 M6 cage nuts, 84 M6 cage screws, 84 plastic washers
Rack Size
19"
Height (Rack Units)
21U
Product Material
SPCC cold rolled steel
50.4 cm x 50.8 cm x 100 cm
15.2 kg
Square hole, adjustable depth 12" - 20", G-shaped mounting rail profile
5-year warranty
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Placing / Mounting
Wall mountable
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
21U
50.4 cm
50.8 cm
100 cm
15.2 kg
43 cm x 120 cm x 17 cm / 20.2 kg
Weight Limit
90 kg
EIA-310-E, ECA-310-E, ISTA 6
Limited warranty: - 5 years
GTBQ StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
GTBQ StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
GTBQ StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.45
GTBQ StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £34.53
GTBQ StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
GTBQ StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
GTBQ StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
GTBQ StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
GTBQ StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £35.51
GTBQ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.31
GTBQ StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.03
GTBQ StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.16
GTBQ StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £20.58
GTBQ StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £25.63
GTBQ StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £65.84
GTBQ StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.18
GTBQ StarTech.com 50 Pkg M6 Cage Nuts In Stock £22.74
GTBQ StarTech.com 100 Pkg M5 Cage Nuts In Stock £34.53
GTBQ StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
GTBQ StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
GTBQ StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
GTBQ StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
GTBQ StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
GTBQ StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
GTBQ StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.34
GTBQ StarTech.com 100 Pkg M6 Cage Nuts In Stock £30.84
GTBQ Startech.com 100 Pkg M6 Mounting Screws In Stock £28.59
GTBQ StarTech.com 19in Cable Management Panel In Stock £22.95
GTBQ StarTech.com M6 Mounting Screws 50Pack In Stock £17.54
GTBQ StarTech.com 18U Open Frame Equipment Rack In Stock £163.88
GTBQ StarTech.com 24U Open Frame Equipment Rack In Stock £188.57
