Connect two 10/100 Ethernet devices to a single Cat5/Cat5e cable drop. The RJ45SPLITTER 2-to-1 RJ45 Splitter Cable Adapter increases the number of RJ45 network connections on an RJ45 outlet, allowing two 10/100 Ethernet signals through a single Cat5/Cat5e wire.
On one end of the installation the splitter enables you to connect two patch cables from a hub or switch to a single port on a patch panel; while on the other end of the installation the splitter connects to a single Cat5/Cat5e network drop through a wall outlet which can then be split and connected to two separate devices. The patch panel and wall outlet are connected through a single Cat5/Cat5e cable.
- StarTech.com 2-to-1 RJ45 10/100 Mbps Splitter/Combiner - One adapter required at each end of the connection - network splitter
- Network splitter
- Connector
- RJ-45 - male
- Connector (Second End)
- 2 x RJ-45 - female
- Limited lifetime warranty
- Network Cable Type
- Network splitter
- Connector
- RJ-45 - male
