This USB-C to DisplayPort MST Hub enables a connection to two DisplayPort monitors, using a DisplayPort Alternate Mode (DP Alt Mode) capable USB-C host device.
4K at 60Hz with HDR
Multi-Stream Transport (MST) technology combines multiple video signals into a single output signal/stream. This MST Hub separates the single input stream into two independent signals, one for each DisplayPort-enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and luminosity. -
Multitasking Made Easy
Configure the dual-DP displays in extended or mirrored mode. Create a high-performance workstation by adding two independent 4K 60Hz displays. This empowers increased multi-tasking across your organization, resulting in increased productivity. -
Hassle-Free Setup
Windows devices supporting DP Alt Mode over USB-C feature native support for MST. This USB-C to DP hub is compatible Thunderbolt 3/4 and USB4-enabled Windows devices with 11th generation (and later) processors. Plug-and-play installation, with no drivers or software required. The 12in (30cm) built-on cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this dual-monitor splitter is bus-powered, requiring no external power source. This product is backed for 3 years, including free lifetime 24/5 multilingual technical assistance.
- StarTech.com 2-Port USB-C MST Hub, USB Type-C to 2x DisplayPort Multi-Monitor Adapter for Laptop, Dual-DP up to 4K 60Hz w/ DP 1.4 Alt Mode & DSC, HDR, 1ft (30cm) Cable, USB Bus-Powered - Multi-Stream Transport Hub (MST14CD122DP) - video/audio splitter - 2 ports
- Video/audio splitter - 2 ports
- Subtype
- DisplayPort
- Ports
- 2 x DisplayPort
- USB powered, plastic housing, MST support, HDR support, dual display support, DisplayPort Alternate mode, 2.1 channel audio support, DSC
- 14.2 cm x 17 cm x 3 cm
- 108.8 g
- Space grey
- System Requirements
- Microsoft Windows 10 / 11
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- DisplayPort
- Ports
- 2 x DisplayPort
- Max Resolution
- 4K @ 60 Hz
- 2 x DisplayPort
- Space grey
- Cables Included
- 1 x USB-C cable - 30 cm
- Plug and Play, RoHS, WEEE, RCM, DisplayPort 1.2, DisplayPort 1.4, HDCP 2.2, DSC, Thunderbolt 3, Thunderbolt 4
- OS Required
- 14.2 cm
- 17 cm
- 3 cm
- 108.8 g
- Limited warranty - 3 years , Technical support - assistance - lifetime
- 0 °C
- 40 °C
- 5 - 90% RH (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £14.89 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £15.92 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £17.05 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £33.78 |
StarTech.com 13ft DisplayPort 1.4 8K 60Hz | In Stock | £36.17 |
StarTech.com 16ft DisplayPort 1.4 8K 60Hz | In Stock | £38.32 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H2Z1 048656 Condition: Customer return - item has been opened but is in excellent condition |
£40.68 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
