The PCI2S950 2 Port PCI RS232 Serial Adapter Card with 16950 UART offers two high performance 16C950 serial UART channels/ports using a single PCI slot. Perfect for connecting new or legacy serial peripherals to your system, with data transfer rates of up to 460.8 Kbps.
The PCI-based RS232 Serial card is a cost-effective solution for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more, without having to upgrade peripherals for USB compatibility.
Installation is a breeze with support for a broad range of Windows operating systems. Plus, IRQ sharing and a PCI plug and play interface guarantee convenient, hassle-free connections.
- StarTech.com Port PCI RS232 Serial Adapter Card with 16950 UART - serial adapter - PCI - 2 ports
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports Qty
- 2 ports
- Data Link Protocol
- Serial
- Data Transfer Rate
- 15 Mbps
- System Requirements
- Windows 10 (32/64 bits)
- Limited lifetime warranty
- Serial adapter - 2 ports
- Form Factor
- Plug-in card
- PCI
- Connectivity Technology
- Wired
- Serial
- 15 Mbps
- 2 x serial - 9 pin D-Sub (DB-9) - male - 2
- Compatible Slots
- 1 x PCI
- OS Required
- Limited warranty - parts and labour - lifetime - carry-in
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
