This Hybrid KVM Switch enables users to switch between a USB Type-A and HDMI-enabled desktop and a USB Type-C (DP Alt-Mode) enabled laptop, to share a keyboard, mouse, audio input/output devices, and a single 4K 60Hz HDMI monitor.
Hassle-Free Setup
The KVM switch is bus powered and features built-in HDMI, USB-A, USB-C, and 3.5mm Audio Input/Output cables. This ensures compatibility and performance between the KVM switch, monitors, and peripherals - without the need to select and purchase the cables required for those connections. -
Compatibility
The 2-port KVM switch is compatible with all operating systems, including Windows, macOS, ChromeOS, and Linux. The KVM works with all hardware platforms including Intel, AMD, and Apple M1/M2. The USB-C host port works with USB-C, USB4, Thunderbolt 3, and Thunderbolt 4 laptops. If the desktop does not have a 4-position 3.5mm port the included 3.5mm Headset Adapter ensures compatibility out of the box. -
Intuitive Control
The KVM switch offers two options to switch between hosts - a remote push button or hotkey commands. The remote push button includes a 1.5m cable for optimal placement in the setup. Independent audio switching can be achieved through the software, ensuring uninterrupted audio when switching between host devices. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
- StarTech.com 2-Port Hybrid USB-C HDMI Cable KVM Switch, 4K 60Hz, Compact KVM with 6ft/1.8m USB-A/HDMI/Audio & 4ft/1.2m USB-C Integrated Host Cables, Bus Powered - Remote Push Button/Hotkey Switching (C2-H46-UAC-CBL-KVM) - KVM / audio / USB switch - compact - 2 ports
- KVM / audio / USB switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- USB powered, remote switch, DisplayPort Alternate mode, 2.1 channel audio support, ABS housing
- USB 2.0
- 9.2 cm x 9.7 cm x 2.4 cm
- 265 g
- Black
- System Requirements
- Linux, Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 4096 x 2160 @ 60 Hz
- USB powered, remote switch, DisplayPort Alternate mode, 2.1 channel audio support, ABS housing, Auto Scan mode
- USB 2.0
- Status Indicators
- Port status
- 1 x USB input Type C , 2 x audio input mini-jack , 1 x USB 2.0 Type A , 1 x HDMI input , 2 x USB 2.0 output Type A , 1 x audio output mini-jack , 1 x microphone output mini-jack , 1 x HDMI output
- Black
- Included Accessories
- 4-position to 2 x 3-position 3.5 mm headset adapter
- Cables Included
- 1 x USB-C cable - 1.2 m , 1 x audio cable - 1.2 m , 1 x audio / USB cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x remote control cable - 1.5 m
- MTBF
- 345,059 hours
- RoHS, WEEE
- OS Required
- 9.2 cm
- 9.7 cm
- 2.4 cm
- 265 g
- Shipping Width
- 21 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 6 cm
- Shipping Weight
- 500 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £15.88 |
StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £20.72 |
StarTech.com 2-Port Dual Monitor KVM Switch | In Stock | £164.56 |
StarTech.com 2-Port Hybrid Cable KVM Switch | In Stock | £106.07 |
StarTech.com 2-Port USB-C Cable KVM Switch | In Stock | £91.94 |
StarTech.com 2-Port Dual-Monitor KVM Switch | In Stock | £210.67 |
