StarTech.com 2 Port PCI Express eSATA Controller Adapter Card
Quicklinx: 5CBMWS00 Mfr#: PEXESATA2
  • Windows 8 (32/64 bits)
Add 2 eSATA ports to your desktop computer through a PCI Express expansion slot. This 2 Port PCI Express eSATA Controller Adapter Card offers simple connectivity between a host computer and eSATA devices. Providing two eSATA ports the adapter card offers a cost-effective solution for connecting hot-pluggable, high-speed storage, and in turn allows for easier data backups and archiving.
With full support for SATA 300 (SATA II) hard drives and data transfer speeds of up to 3 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA storage needs.
The PCI Express eSATA controller card also features port multiplier capability with command-based switching for connecting multiple external hard drives to a host Windows system through a single external SATA connection.
A dual profile solution, the eSATA controller card includes a low profile/half-height bracket for adapting to slimline or small form factor system applications.
StarTech.com 2 Port PCI Express eSATA Controller Adapter Card - storage controller - eSATA 3Gb/s - PCIe x1
Storage controller - plug-in card - low profile
Bus Type
PCIe x1
eSATA 3Gb/s
Channel Qty
2
Max Storage Devices Qty
2
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
P/N: S3540BU33E, SDOCKU33EBV
Host Bus
PCIe x1
Storage Controller
eSATA 3Gb/s
Channel Qty
2
2
2 x SATA 3Gb/s - eSATA (external)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
5CBM StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.58
Resources
The following resources are available for the StarTech.com 2 Port PCI Express eSATA Controller Adapter Card
