This laptop cable lock gives you an easy and effective way to secure your notebook to a sturdy object and keep it safe from theft. With this 4-digit combination laptop lock, you can be confident your laptop and valuable data are well protected. You can ensure that your laptop, computer, monitor, docking station or other electronic device will be anchored safely to your workspace in just a few simple steps with this keyless 4-digit combo lock with security cable.
Strong and durable
Featuring a vinyl-coated steel cable, this laptop lock is designed for effective theft prevention. The portable combination laptop lock also features a helpful reset procedure if the original combination is known. -
Bends with ease
The flexible steel cable bends easily to loop around a stationery post or object, protecting your laptop or docking station against theft.
- StarTech.com 6.5' (2m) Laptop Cable Lock, Nano Slot Compatible 4 Digit Combination Security Cable Lock, Serialized Anti-Theft Vinyl Coated Steel Cable Lock for Nano Slot Computer/Device - Nano Slot Laptop Lock (LTLOCKNANO) - Compatible with Kensington - security cable lock
- Product Type
- Security cable lock
- Package Content
- Hook-and-loop tie
- Product Material
- Vinyl-coated steel
- 2.83 cm 1.6 cm
- Length
- 2 m
- 135 g
- 4 digit code, anti-theft protection, flexible steel cable
- 2-year warranty
- Product Type
- Product Material
- Package Content
- Hook-and-loop tie
- 2.83 cm
- 1.6 cm
- Length
- 2 m
- 135 g
- Shipping Dimensions (WxDxH) / Weight
- 20 cm x 22 cm x 2 cm / 139 g
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- Nano
- Lock Method
- Combination
- RoHS, REACH
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Nano Laptop Cable Lock | In Stock | £39.66 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £32.01 |
