This 2.5in to 3.5in IDE Hard Drive Adapter cable provides a 44-pin female IDE connector and a 40-pin male IDE connector as well as an LP4 power supply connection, allowing you to connect a 2.5in IDE laptop hard drive to a desktop computer.
- StarTech.com 2.5in to 3.5in IDE Hard Drive Cable Adapter - IDE / EIDE adapter
- Connectors
- 44 PIN IDC - female
- Connectors (Second End)
- 40 PIN IDC - male , Power 4-pole - male
- Limited lifetime warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, UNIDOCKU33
- Storage Cable Type
- Connectors
- Designed For
Customer reviews
Write a review for the StarTech.com 2.5in to 3.5in IDE Hard Drive Cable Adapter here!
Perfect!
Reviewed by Pete. Review Posted 08/04/2008
This has to be the best buy i have ever done. Easy to use, cheap and delivery was fast: ordered friday, arrived Tuesday! I had a few problems at first but they were my own fault. Just glad to have my old files back. THANK YOU DABS! I Recommend if you need a converter for an old laptop HDD
Overall
Ease of use
Value for money
Very good
Reviewed by Andrew. Review Posted 22/01/2007
Does exactly what it says on the tin!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
