Improve the cooling flow and appearance of your racks and cabinets by filling the gaps between equipment. The BLANKB1 1U Rack Blank Panel for 19in Server Racks and Cabinets is designed to EIA RS-310-C specifications and fits all 19" standard server racks and cabinets.
Ideal for improving airflow within the rack by covering the unused spaces, the filler panel/blank panel is constructed of cold-rolled steel and features a black powder coated finish that matches most industry standard black server cabinets and racks.
- StarTech.com 1U Blanking Panel - Metal Rack Mount Filler Panel - for 19in Server Rack Enclosure or Cabinet - Steel - Black (BLANKB1) - blank panel - 1U
- Product Type
- Blank panel
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- Cold-rolled steel
- 48.3 cm x 1.5 cm x 4.4 cm
- 339 g
- Limited lifetime warranty
- Designed For
- P/N: RK1236BKF, RK2536BKF, RK4236BKB, RK619WALL, RK619WALLGB, RK960CP
- Product Type
- Blank panel
- Product Material
- Cold-rolled steel
- Rack Size
- 19"
- 1U
- 48.3 cm
- 1.5 cm
- 4.4 cm
- 339 g
- Black
- RoHS
- Limited warranty: - lifetime
- Designed For
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £99.99 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £34.53 |
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £7.35 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £12.78 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £119.50 |
StarTech.com 19in Cable Management Panel | In Stock | £22.95 |
