Add a sturdy, adjustable depth shelf into almost any server rack or cabinet. The ADJSHELF Adjustable Mounting Depth Rack Mount Shelf offers a simple way to effectively organize mission critical computer hardware in your server racks and cabinets.
Compatible with all 19in (wide) server racks/cabinets, the fixed rack shelf can be adjusted from 19in to 38in (mount depth) as necessary. A sturdy cold-rolled steel construction provides long term durability and enables a weight capacity of up to 175 lbs (80 kg).
- StarTech.com 1U Adjustable Vented Server Rack Mount Shelf - 175lbs - 19.5 to 38in Deep Universal Tray for 19" AV/ Network Equipment Rack (ADJSHELF) - rack shelf - 1U
- Product Type
- Rack shelf
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- 44.5 cm x 70 cm x 4 cm
- 4.4 kg
- Adjustable depth, vented
- 1-year warranty
- Designed For
- P/N: 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM62, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1233BKM, RK1236BKF, RK1536BKF, RK1833BKM, RK1836BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RKQMCAB12
- Product Type
- Rack shelf
- Rack Size
- 19"
- 1U
- 44.5 cm
- 70 cm
- 4 cm
- 4.4 kg
- Black
- Weight Limit
- 79.4 kg
- RoHS
- Limited warranty: - 1 year
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1233BKM, RK1236BKF, RK1536BKF, RK1833BKM, RK1836BKF, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £99.99 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £83.08 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £34.53 |
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £7.34 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £12.78 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £92.59 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £120.51 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £68.86 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £88.30 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £92.81 |
StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co | In Stock | £32.84 |
