StarTech.com 1U 17" HD 1080p Dual Rail Rackmount LCD Console w/ Fingerprint Reader and Front USB Hub
Quicklinx: 97F7WS00 Mfr#: RKCOND17HDGB
Control server equipment from a Full HD KVM console, with a convenient dual-rail slide design. The RKCOND17HDGB Dual Rail LCD Rack Console lets you control server equipment from a centralized, 17in 1080p KVM console, with an integrated 2-port front USB hub and fingerprint reader.
The dual-rail system allows the display to slide independently from the keyboard/touchpad tray, enabling you to use the console as a monitoring station while the keyboard is stored in the rack.
The integrated single port KVM module offers universal support for DVI or VGA, and USB or PS/2 console connections and includes all of the necessary cabling to get you up and running. Connect the console to either a single system, or a multi-port KVM switch to manage multiple systems. Plus, the front panel USB hub places two easily accessible USB 2.0 ports at your disposal for connecting external storage and other peripherals as needed.
This rackmount LCD also includes a physical key-lock and a bio-metric fingerprint reader to provide an extra layer of security in your server room. The fingerprint reader can be configured for access control, application/file launching and also to create and access virtual secure storage drives for different users.
StarTech.com 1U 17" HD 1080p Dual Rail Rackmount LCD Console w/ Fingerprint Reader and Front USB Hub - KVM console - Full HD (1080p) - 17"
KVM console - 17"
KVM Switch
PS/2, USB
Keyboard, touchpad, fingerprint reader
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
650:1
Colour Support
16.7 million colours
Input Connectors
DVI-I, VGA
Voltage
AC 90 - 240 V
44.8 cm x 46 cm x 4.4 cm
Height (Rack Units)
1U
13 kg
FCC, RoHS
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Built-in Devices
Fingerprint reader
Native Resolution
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
650:1
Colour Support
Horizontal Viewing Angle
140
Vertical Viewing Angle
120
Height (Rack Units)
1U
13 kg
Input
Keyboard, touchpad
KVM
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1920 x 1080 / 1080p
DVI-I , VGA (HD-15) , 2 x USB (Type A) , Keyboard (PS/2) , Mouse (PS/2)
Key lock
1 x DVI cable , 1 x keyboard / mouse / video cable , 1 x USB cable
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
FCC, RoHS
Power Supply
External
Input Voltage
AC 90 - 240 V
Power Consumption (Typical)
23.35 Watt
Included Software
Drivers & Utilities
50 °C
10 - 90%
97F7 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £551.61
97F7 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £292.39
