Connect your USB Type-C devices to your computer, with the cable out of the way. This right-angle USB to USB-C cable is great for charging your mobile devices in a car, or for accessing your phone or tablet while it's connected to a wall charger or laptop.
The cable features a right-angled USB Type-C connector that lets you connect to ports that are difficult to reach, which is perfect for charging your car-mounted mobile devices. You can position the cable to the left or right of your mobile device, in either portrait or landscape mode. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way.
The angled connector also prevents the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection point, preventing unnecessary stress and damage to the cable and device port.
Replace the USB to USB-C cable that came with your mobile device, or keep one as a spare while traveling so that your mobile devices will be ready to use while you're on the road.
Connect with ease
The cable features a right-angled USB Type-C connector that lets you connect to ports that are difficult to reach, which is perfect for charging your car-mounted mobile devices. You can position the cable to the left or right of your mobile device, in either portrait or landscape mode. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way. -
Charge and sync your USB mobile devices
Replace the USB to USB-C cable that came with your mobile device or keep one as a spare while traveling so that your mobile devices will be ready to use while you're on the road.
- StarTech.com USB to USB C Cable - 1m / 3 ft - Right Angle USB Cable - USB A to USB C Cable - USB 2.0 Cable - USB Type C Cable (USB2AC1MR) - USB cable - USB to 24 pin USB-C - 1 m
- USB cable
- Sync and charge
- Length
- 1 m
- Connector
- 4 pin USB Type A - male - straight
- Connector (Second End)
- 24 pin USB-C - male - right-angled
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Nickel
- Sync and charge
- Length
- 1 m
- Black
- 50 g
- Connector
- USB / USB 2.0, RoHS, WEEE
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 0.5m USB 2.0 C to A Cable M/M | In Stock | £7.94 |
StarTech.com 1m USB A to C Cable - USB 2.0 | In Stock | £11.30 |
StarTech.com 1m Right Angle USB C Cable | In Stock | £11.60 |
