View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 1m away from your DVI-D display. The HDDDVIMM1M 1m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 3ft (1m) Slim 3.5mm Stereo Audio Cable (MU3MMS).
The HDDDVIMM1M is designed and constructed for maximum durability, to ensure dependable performance.
- StarTech.com 1m Micro HDMI to DVI-D Cable - M/M - Video cable - HDMI / DVI - DVI-D (M) to micro HDMI (M) - 3.3 ft - shielded - black - HDDDVIMM1M - adapter cable - HDMI / DVI - 1 m
- Cable
- Adapter cable - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 1 m
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- 19 pin micro HDMI Type D - male
- Moulded, strain relief
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Gold
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
- Limited warranty - lifetime
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.14 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £9.80 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.14 |
StarTech.com 2m Micro HDMI to DVI-D Cable - M/M | In Stock | £12.91 |
StarTech.com 1m Micro HDMI to DVI-D Cable - M/M | In Stock | £11.85 |
