StarTech.com 1m Micro HDMI to DVI-D Cable - M/M
Quicklinx: 95F5WS00 Mfr#: HDDDVIMM1M
Length: 1m
12 In Stock
£11.85 ex VAT
£14.22 inc VAT
View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 1m away from your DVI-D display. The HDDDVIMM1M 1m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 3ft (1m) Slim 3.5mm Stereo Audio Cable (MU3MMS).
The HDDDVIMM1M is designed and constructed for maximum durability, to ensure dependable performance.
StarTech.com 1m Micro HDMI to DVI-D Cable - M/M - Video cable - HDMI / DVI - DVI-D (M) to micro HDMI (M) - 3.3 ft - shielded - black - HDDDVIMM1M - adapter cable - HDMI / DVI - 1 m
Cable
Adapter cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
30
Length
1 m
Connector
DVI-D - male
Connector (Second End)
19 pin micro HDMI Type D - male
Moulded, strain relief
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Shielded
30
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Gold
Connector
18+1 pin digital DVI (Single-Link) - male
RoHS
Limited warranty - lifetime
95F5 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
95F5 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.78
95F5 StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.59
95F5 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.80
95F5 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £10.14
95F5 StarTech.com 2m Micro HDMI to DVI-D Cable - M/M In Stock £12.91
95F5 StarTech.com 1m Micro HDMI to DVI-D Cable - M/M In Stock £11.85
Length: 1m
