StarTech.com 18in Right Angle SATA Cable - F/F
Quicklinx: 5FF8WS00 Mfr#: SATARA18
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATARA18 Right Angle (90-degree) SATA cable (18in) enables you to plug in your SATA hard drive in hard to reach areas or tight spaces, using right-angled SATA connectors to reduce the amount of space required at the connection point and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 18in Right Angle SATA Cable - F/F - SATA cable - 45.7 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Right-angled connector
Length
45.7 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25SAT35HDD, BRACKET25SAT, PEXESAT322I, PEXMSATA3422, PEXMSATA343, PEXSAT34RH
Storage Cable Type
SATA cable
Interface Speed
Length
45.7 cm
Red
Connector
