StarTech.com 15U Wall-Mount Server Rack
Quicklinx: D5BHWS00 Mfr#: RK15WALLOA
£114.82 ex VAT
£137.78 inc VAT
Mount your server or networking equipment to the wall, using this adjustable 15U open frame rack. This open-frame wall-mount server rack provides 15U of storage, helping you to save space and stay organized. The equipment rack features an adjustable depth and can hold a total of up to 198 lb. (90 kg).
With adjustable depth to as low as 12 in. (30.4 cm) this network rack is perfect for smaller spaces. It's easy to assemble and features wall-mounting holes that are spaced 12 and 16 in. apart, making it suitable for mounting on almost any wall, based on North American wall-frame stud-spacing standards. The wall-mount rack comes in a flat-pack, which makes it easy to transport and saves you money on shipping.
The open-frame rack adjusts from 12 to 20 in. (30.4 to 50.8 cm) to accommodate larger data, network, and telecommunication devices. The above-average depth also gives you the option to mount shelves and other accessories.
When space is limited you can mount the open-frame rack on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
The rack's open frame design ensures passive cooling for your rack-mounted equipment. Additionally, the open frame provides easy access to your equipment and makes it easier to configure mounted devices, which saves you time.
  • Accommodate Larger Devices
    The open frame rack adjusts from 12 to 20 inches (30.4 to 50.8 cm) to accommodate larger data, network, and telecommunication devices. The above-average depth also gives you the option to mount shelves and other accessories.
  • Free up Floor Space
    When space is limited you can wall-mount the open-frame rack in a server room, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
  • Keep Equipment Cool and Accessible
    The rack's open frame design promotes passive cooling; ensures easy access to your rack-mounted equipment and makes it simple to configure mounted devices, which saves you time.
  • Easy, Hassle-Free Installation
    With an adjustable depth as low as 12 inches (30.4 cm), this network rack is perfect for smaller spaces. It's easy to assemble and features wall-mounting holes that are spaced 12 and 16 in. apart, making it suitable for mounting on almost any wall, based on North American wall-frame stud-spacing standards.
StarTech.com 15U 19" Wall Mount Network Rack, Adjustable Depth 12-20" 2 Post Open Frame Server Room Rack for AV/Data/ IT Communication/Computer Equipment/Switch with Cage Nuts & Screws - 15U Adjustable Rack - rack - 15U
Rack
Placing / Mounting
Wall mountable
Package Content
2 vertical rails, 2 front horizontal brackets, 2 rear horizontal brackets, 16 assembly screws, 24 flat washers, 24 bolts, 60 M6 cage nuts, 60 M6 screws, 60 plastic washers
Rack Size
19"
Height (Rack Units)
15U
Product Material
Steel
51 cm x 50.4 cm x 78 cm
15.2 kg
Adjustable depth, 2 post
5-year warranty
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
15U
51 cm
50.4 cm
78 cm
15.2 kg
53 cm x 80 cm x 13 cm / 17.8 kg
Weight Limit
90 kg
Limited warranty: - 5 years
D5BH StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
D5BH StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.51
D5BH StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
D5BH StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.56
D5BH StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
D5BH StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
D5BH StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.04
D5BH StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
D5BH StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.36
D5BH StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.45
D5BH StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.94
D5BH StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
D5BH StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.96
D5BH StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.35
D5BH StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.09
D5BH StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.44
D5BH StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
D5BH StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.46
D5BH StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
D5BH StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.59
D5BH StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £54.01
D5BH StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £29.06
D5BH StarTech.com 50 Pkg M5 Mounting Screws In Stock £16.04
D5BH StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.99
D5BH StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.75
D5BH StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.29
D5BH StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
D5BH StarTech.com 19in Cable Management Panel In Stock £23.30
D5BH StarTech.com 12U Wall-Mount Server Rack In Stock £103.24
D5BH StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
D5BH StarTech.com 18U Open Frame Equipment Rack In Stock £163.29
D5BH StarTech.com 21U Open Frame Equipment Rack In Stock £161.73
D5BH StarTech.com 24U Open Frame Equipment Rack In Stock £187.89
