Notebook Privacy Filter, Blue Light Reduction Matte or Glossy 2-Year Warranty. The laptop privacy screen is easy to attach and remove. Simply attach the notebook privacy filter to your laptop using the magnetic strips. This black out privacy screen is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect your Privacy
The laptop privacy filter is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. Whether travelling, working in the office or sitting in a busy coffee shop, you can have a peace of mind because you know your screen is protected with the 30+/- degree privacy viewing angle.
The display privacy filter is designed to filter blue light (390nm~480 wavelength) that can cause eye strain and can disrupt sleeping patterns.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
This PRIVSCNLT15 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Easy Magnetic Installation
The laptop privacy screen is very easy to install and remove. Simply attach the adhesive magnetic strips to the bezel of your display then align the notebook privacy filter with the strips. This black out privacy screen is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity. In order to close and put your laptop to sleep the privacy screen must be removed. A protective folder is included so you can protect the privacy screen from damage when not in use. The privacy screen is also extremely easy to clean when removed from your laptop. -
The laptop privacy filter is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. Whether travelling, working in the office or sitting in a busy coffee shop, you can have a peace of mind because you know your screen is protected with the 30+/- degree privacy viewing angle. -
With working from home becoming more prominent and screen time on the rise, reducing blue light exposure is important. The monitor privacy film is designed to filter blue light (390nm~480 wavelength) and reduce digital eye strain. -
Antimicrobial Protection
Our privacy screens feature an anti-microbial coating on the matte-side of the filter. Embedded antimicrobial technology provides protection against bacterial microbes by continuously eliminating up to 99.99% of certain surface bacteria. Antimicrobial screen protectors are ideal for environments where disinfection is important. -
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The TAA compliant PRIVSCNLT15 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Laptop Privacy Screen for 15" Notebook, Magnetic Removable Laptop Display Security Filter, Blue Light Reducing Screen Protector, 16:9, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter (PRIVSCNLT15) - notebook privacy filter
- Product Type
- Notebook privacy filter
- Installation Type
- Removable - magnetic
- Package Content
- Wiping cloth, metal strip, L folder
- Transparent
- Product Material
- Plastic
- 35.5 cm 21.3 cm
- 52 g
- Display Screen Size Compatibility
- 15"
- Anti-glare, reversible, +/- 30° visible angle, 25% blue light reduction
- 2-year warranty
- Designed For
- P/N: LTSTND2IN1
- Product Type
- Product Material
- Plastic
- Package Content
- 35.5 cm
- 21.3 cm
- 52 g
- Shipping Dimensions (WxDxH) / Weight
- 25.9 cm 38.3 cm / 214 g
- 15"
- Transparent
Display Filter
- Installation Type
- Aspect Ratio
- 16:9
- Scratch Resistant
- RoHS, REACH
- TAA Compliant
- Limited warranty: - 2 years
- Designed For
- P/N: LTSTND2IN1
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £35.68 |
StarTech.com 15in Laptop Privacy Screen - Magnetic - 16:10 Aspect Ratio | In Stock | £53.24 |
StarTech.com Laptop Stand for Desk | In Stock | £72.84 |
StarTech.com 13.3in Laptop Privacy Screen | In Stock | £34.04 |
StarTech.com 14in Laptop Privacy Screen | In Stock | £32.22 |
StarTech.com 14in MacBook Privacy Screen | In Stock | £31.55 |
StarTech.com 16in MacBook Privacy Screen | In Stock | £32.11 |
StarTech.com 13.5in Laptop Privacy Screen | In Stock | £31.59 |
StarTech.com 15.6" Laptop Privacy Filter | In Stock | £33.05 |
StarTech.com 17.3" Laptop Privacy Filter | In Stock | £33.27 |
StarTech.com 14in MacBook Privacy Screen | In Stock | £32.56 |
StarTech.com 14in Laptop Privacy Screen | In Stock | £31.27 |
StarTech.com 15.6in Laptop Privacy Screen | In Stock | £27.85 |
StarTech.com 16in MacBook Privacy Screen | In Stock | £32.79 |
