Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 15ft long cable. The DP2VGAMM15B 15ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector at a longer distance than a standard-length cable would support, while saving the expense of additional adapters.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 15 ft DisplayPort to VGA Adapter Cable - DP to VGA Video Converter - Active DisplayPort to VGA Cable for PC 1920x1200 - Black (DP2VGAMM15B) - DisplayPort cable - 4.57 m
- DisplayPort cable
- Latched
- Length
- 4.57 m
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - male
- FCC, RoHS
- Black
- 3-year warranty
- DisplayPort cable
- Latched
- Length
- 4.57 m
- Black
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - male
- FCC, RoHS
- 3-year warranty
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £24.19 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.80 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £20.60 |
StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £8.14 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.05 |
StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £22.06 |
StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £23.42 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £23.78 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £16.29 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £23.64 |
StarTech.com DisplayPort to VGA Adapter - 1920x1200 | In Stock | £70.87 |
