Mount smaller rack mountable devices right at your desk with this lightweight 12U 2 post desktop rack. The RK12OD 12U 19in Desktop Open Frame 2 Post Rack provides the perfect mounting option for smaller Audio/Video and IT equipment where space is limited and a full sized cabinet is not required.
The 12U rack features a compact and lightweight free-standing design that is suitable for installation on or around your desk giving you easy access to the mounted equipment in your workspace. This lightweight 2 post rack is engineered to meet EIA rack mount standards and includes a pack of 20 M5 screws and Cage Nuts, allowing you to mount up to five devices into the rack right away.
- StarTech.com 12U Open Frame Network Rack - 19" 2 Post Free Standing Desktop Rack for Computer, AV, Media, IT, Data & Server Room Equipment (RK12OD) - rack - 12U
- Product Type
- Rack
- Rack Type
- Open frame
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 12U
- Product Material
- Steel
- 50.4 cm x 29.2 cm x 58.4 cm
- 3-year warranty
- Designed For
- P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
- Product Type
- Rack
- Rack Type
- Open frame
- Product Material
- Steel
- Rack Size
- 19"
- 12U
- 50.4 cm
- 29.2 cm
- 58.4 cm
- Black
- UL, RoHS
- Limited warranty: - 3 years
- Designed For
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £490.32 |
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £40.85 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £45.21 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £39.32 |
StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £44.32 |
StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £53.59 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £48.25 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.39 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £34.53 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £337.14 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £16.28 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £32.84 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.33 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £65.84 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £28.76 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £292.39 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £319.01 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £657.69 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £35.51 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £55.50 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £45.85 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £39.89 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £54.45 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.16 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £20.58 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £65.84 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £32.13 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £22.74 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £34.53 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £17.25 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £62.33 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £32.84 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £18.34 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £34.53 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £19.35 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.55 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £30.84 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £555.17 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £28.59 |
StarTech.com 19in Cable Management Panel | In Stock | £23.15 |
StarTech.com 2-Post Desktop Rack - 8U | In Stock | £37.91 |
StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co | In Stock | £32.84 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £32.74 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £17.54 |
