StarTech.com 12in 4 Pin Fan Power Extension Cable - M/F
Quicklinx: 7NXYWS00 Mfr#: FAN4EXT12
Length: 3m
Type: Power
39 In Stock
£4.34 ex VAT
£5.20 inc VAT
The FAN4EXT12 12-inch 4-Pin Fan Power Extension Cable lets you extend the power connection between a computer power supply and a 4-pin fan by up to 1ft, enabling you to conveniently install the fan where needed in the computer case, without having to stretch or strain the connection.
StarTech.com 12in 4 Pin Fan Power Extension Cable - M/F - Fan power extension cable - 4 pin PWM (M) to 4 pin PWM (F) - FAN4EXT12 - fan power extension cable - 4 pin PWM to 4 pin PWM - 3 m
Length
3 m
Connector
4 pin PWM - male
Connector (Second End)
4 pin PWM - female
American Wire Gauge (AWG)
28
Length
3 m
Connector
4 pin PWM - male
4 pin PWM - female
Length: 3m
Type: Power
