StarTech.com 100 Pkg M5 Mounting Screws
Quicklinx: BT5HWS00 Mfr#: CABSCREWSM5B
Product Type: Screw kit
Hurry, only 1 left in stock!
£34.53 ex VAT
£41.43 inc VAT
Install your rack-mountable hardware securely with these high-quality screws. This 100-pack of M5 mounting screws is convenient to have on hand for installing rack-mountable equipment, such as your server, network or audio/video equipment.
They are also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a screw or two. The bulk package ensures that you have enough screws available for all of your installations, when you need them.
The server rack screws come in an all-black finish for a seamless look.
StarTech.com M5 x 12mm - Screws - 100 Pack, Black - M5 Mounting Screws for Server Rack & Cabinet (CABSCREWSM5B) - screw kit
Screw kit
Packaged Quantity
100 (specifications are for single item)
Package Content
M5 screw
Product Material
Steel
0.5 cm x 1.2 cm
210 g
P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2, WALLMOUNT4
Packaged Quantity
Screw kit
Product Material
Steel
Package Content
M5 screw
0.5 cm
1.2 cm
210 g
Limited warranty: - 2 years
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK219WALLV, RK219WALVO, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK319WALLV, RK3236BKF, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK619WALLV, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, WALLMNT12, WALLMOUNT4, WALLMOUNT6, WALLMOUNT8, WALLMOUNTH1, WALLMOUNTH2, WALLMOUNTH4
BT5H StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £252.52
BT5H StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £237.02
BT5H StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £205.22
BT5H StarTech.com 100 Pkg M5 Cage Nuts In Stock £34.53
BT5H StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
BT5H StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
BT5H StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
BT5H StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
BT5H StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
BT5H StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
BT5H StarTech.com 2-Post Server Rack - 42U In Stock £157.38
