0.47 in. (12 mm) Max. Bundle Diameter 100 Pack Black Small Self-Adhesive TAA. These self adhesive one-piece black cable clamps provides an easy way to secure and organize cables in multiple locations. 100 Black cable clips are included, ensuring you'll have plenty on hand.
Keep Cables Organized
The cable clips support a 0.47 in. (12 mm) cable bundle diameter and mount to any wall with the included 3M adhesive backing. There's also a 0.21 in. (5.3 mm) mounting hole for added strength. The one-piece cable clamp can be opened and repurposed with different cables.
Industrial Strength
Made of durable black nylon 66 material and featuring a strong 3M adhesive sticky backing these cable holders are UL94 V-2 fire rated at up to 85°C.
Available in Different Sizes
To suit any application, StarTech.com offers a selection of these cable clamps in different sizes:
Small Cable Clamps (CBMCC1)
Medium Cable Clamps (CBMCC2)
Large Cable Clamps (CBMCC3)
These cable clamps are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
The cable clips support a 0.47 in. (12 mm) cable bundle diameter and mount to any wall with the included 3M adhesive backing. There's also a 0.21 in. (5.3 mm) mounting hole for added strength. The one-piece cable clamp can be opened and repurposed with different cables. -
Industrial Strength
Made of durable black nylon 66 material and featuring a strong 3M adhesive sticky backing these cable holders are UL94 V-2 fire rated at up to 85°C. -
To suit any application, StarTech.com offers a selection of these cable clamps in different sizes: Small Cable Clamps (CBMCC1) Medium Cable Clamps (CBMCC2) Large Cable Clamps (CBMCC3) These cable clamps are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
- StarTech.com 100 Adhesive Cable Management Clips Black, Network/Ethernet/Office Desk/Computer Cord Organizer, Sticky Cable/Wire Holders, Nylon Self Adhesive Clamp UL/94V-2 Fire Rated - Nylon 66 Plastic - TAA (CBMCC2) - cable clips - TAA Compliant
- Product Type
- Cable clips
- Packaged Quantity
- 100 (specifications are for single item)
- 3.5 cm x 1.7 cm x 1.9 cm
- 3.3 g
- Product Material
- Nylon 6-6
- Black
- TAA Compliant
- 2-year warranty
- Packaged Quantity
- Product Type
- Cable clips
- Product Material
- Nylon 6-6
- 3.5 cm
- 1.7 cm
- 1.9 cm
- 3.3 g
- Enclosure Colour
- Black
- Self-adhesive, UL 94V-2 Rated, 12 mm max bundle diameter, 5.3 mm mounting hole size
- TAA Compliant
- Shipping Width
- 27 cm
- Shipping Depth
- 21.5 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 350 g
- Limited warranty - 2 years
StarTech.com 100 Pack of Self-Adhesive Cable Clamp - Small | In Stock | £15.37 |
StarTech.com 100 Pack of Self-Adhesive Cable Clamp - Small | In Stock | £10.52 |
