StarTech.com 10-Pt USB 3.0 Hub w/ Charging
Quicklinx: BT5MWS00 Mfr#: ST103008U2C
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 10
Form Factor: External
14 In Stock
£66.32 ex VAT
£79.58 inc VAT
Add ten USB 3.0 ports, including two charging downstream ports, to your computer. This 10-port USB 3.0 hub enhances your system's capabilities by providing fast-charging for mobile devices, plus quick access to your USB devices, making it perfect for business or home-office settings.
As a charging station, the hub features two easy-access 1.5 amp charge-and-sync ports, so you can easily fast-charge your smartphones, tablets and other mobile devices. Plus, you can still connect all of your vital peripherals to the remaining data ports. Because the hub supports USB Battery Charging Specification 1.2, you can charge most mobile devices, including Apple and Samsung Galaxy devices.
Designed for maximum scalability, this 10-port hub boosts your productivity by putting all of your USB devices within easy reach. With USB 3.0 transfer rates up to 5Gbps, it supports high-bandwidth devices such as external hard drive enclosures, flash drives, high-resolution webcams, video cameras, and more.
With its sleek and compact design, you can easily position the USB 3.0 (also known as USB 3.1 Gen 1) hub on your desk or workspace to make your USB devices more accessible. There's also ample space between the USB 3.0 ports, so it's easy to plug and unplug the devices you use the most.
The USB 3.0 hub is natively supported in virtually all operating systems, which makes for an easy setup with no driver installation required.
  • Fast-charge your mobile devices
  • Increase your productivity with ten USB 3.0 ports
  • Designed for easy use
    With its sleek and compact design, you can easily position the USB 3.0 hub on your desk or workspace to make your USB devices more accessible. There's also ample space between the USB 3.0 ports, so it's easy to plug and unplug the devices you use the most.
StarTech.com 10 Port USB 3.0 Hub with Charge & Sync Ports - 8 x USB-A, 2 x USB-A Fast Charge Ports - Multi Port Powered USB Hub (ST103008U2C) - USB peripheral sharing switch - 10 ports
Subtype
USB
Ports
10 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V 1.5 A
6 cm x 24 cm x 2.4 cm
140 g
Australia, North America, United Kingdom, Europe
P/N: DKWG30DPHPD, DKWG30DPHPDU, TB33A1C, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Enclosure Type
Desktop
Subtype
USB
Ports
1 x VIA VL812
Status Indicators
Port status
10 x USB 3.0 Type A
External power adapter
AC 120/230 V
Electric Current Required
1.5 A
48 Watt
1 x SuperSpeed USB cable
FCC, RoHS, WEEE, RCM
6 cm
24 cm
2.4 cm
140 g
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
BT5M StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £25.64
BT5M StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £22.58
BT5M StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £52.25
BT5M StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £57.29
BT5M StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £66.32
BT5M StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £43.39
BT5M StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £60.86
Type: USB Hub
Speed: 5Gbps
Ports: 10
