StarTech.com 10 ft DB25 to Centronics 36 Parallel Printer Cable - M/M
Quicklinx: 76SVWS00 Mfr#: PB10
Only best-quality components are used when StarTech.com's expert manufacturing team creates its cabling and this cable is not different. Connect a data switch or PC to a parallel printer with the StarTech.com PB10, a standard printer cable. This product helps StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
StarTech.com DB25 to Centronics 36 Parallel Printer Cable - printer cable - 3 m
Printer cable
Length
3 m
Connector
DB-25 - male
Connector (Second End)
36 PIN Centronics - male
P/N: DS252, DS254, EC1PECPS, PCI1P_LP, PCI1PECP, PCI2PECP, PCI2S1P, PEX1P, PEX1P2, PEX1PLP, PEX2PECP2
Printer cable
Length
3 m
Connector
25 pin D-Sub (DB-25) - male
