The ICUSB2321X Professional grade USB Serial Adapter cable converts a USB 2.0 port into an RS232 serial port allowing you to connect to, monitor and control your serial devices. A durable, single cable design makes this the perfect solution for mobile technicians/administrators that require serial connectivity. Once connected, the USB to serial adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading the serial peripheral for USB compatibility.
- StarTech.com USB to Serial RS232 Adapter Cable w/ COM Retention - USB Serial Adapter - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- 3.5 cm 1.3 cm
- Length
- 42 cm
- 33 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 920 Kbps
- Black
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 32-bit Edition
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 920 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB - 4 pin USB Type A
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 3.5 cm
- 1.3 cm
- Length
- 42 cm
- 33 g
- Limited warranty - 2 years
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.75 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £33.25 |
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £20.36 |
StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention | In Stock | £60.96 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £15.32 |
StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention | In Stock | £101.03 |
StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter | In Stock | £25.71 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.33 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £49.60 |
StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter | In Stock | £52.48 |
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M | In Stock | £22.53 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.05 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £102.11 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £177.69 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.35 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £79.29 |
StarTech.com UCB C to Serial Adapter | In Stock | £18.28 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £244.59 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £392.42 |
