StarTech.com 1 Port PCI 10/100/1000 32 Bit Gigabit Ethernet Network Adapter Card
Quicklinx: 7R30WS00 Mfr#: ST1000BT32
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
40 In Stock
£12.85 ex VAT
£15.42 inc VAT
Add a 10/100/1000Mbps Ethernet port to any PC through a PCI slot. This PCI-based 10/100/1000 Mbps Gigabit Ethernet Network Adapter Card provides a simple connection to a Gigabit Ethernet network, and is fully compatible with IEEE 802.3, 802.3u, 802.3ab and 802.3x standards.
Suitable for any PCI-enabled client, server or workstation, the Gigabit Ethernet Network Adapter Card supports high performance dual channel networking and maximum data transfer speeds of 1000Mbps in each direction (2000 Mbps total) - up to ten times faster than 10/100 Ethernet.
Compatible with a broad range of operating systems, including Linux, Windows 10, 8/8.1, 98SE, ME, 2000, XP, XP-64bit, Vista, Vista-64bit, 7, 7-64bit as well as Mac OS 10.4, this high quality PCI Gigabit NIC includes an optional low profile bracket that makes it easy to install the card in a small form factor/low profile computer case/server.
StarTech.com 1 Port PCI 10/100/1000 32 Bit Gigabit Ethernet Network Adapter Card (ST1000BT32) - network adapter - PCI - Gigabit Ethernet
Network adapter
Plug-in card
Interface (Bus) Type
PCI
Ports
Gigabit Ethernet
14.4 cm x 6.3 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
UNIX, Novell NetWare 5.x, Microsoft Windows NT, Microsoft Windows Server 2003, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/ME/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019
Network adapter
Plug-in card
PCI
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port transmission speed, link/activity
Flow control, full duplex capability, VLAN support, WOL
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI
FCC Class B certified
Software Included
Drivers & Utilities, Novell NetWare ODI for DOS
14.4 cm
6.3 cm
Limited warranty - lifetime
55 °C
7R30 StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card In Stock £45.13
7R30 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £23.31
7R30 StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £20.55
7R30 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White In Stock £22.26
7R30 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £22.06
7R30 StarTech.com 1 Port PCI Express PCIe Gigabit NIC Server Adapter Network Card - Low Profile In Stock £20.19
7R30 StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - PCIe NIC In Stock £86.90
Protocol: Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
