This 2.5 GbE M.2 Network Interface Card (NIC) features an Intel I225-V chipset with Intel vPro technology, for enhanced performance and data integrity. Variable multispeed options (2.5/1Gbps and 100/10Mbps) enable support of new and legacy network hardware. Leverage existing Cat5e or CAT6 cabling infrastructure while adding 2.5GBASE-T (802.3bz) compatibility for seamless integration.
Increased Network Speed
The PCIe network card takes advantage of Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and online content streaming or uploading while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment. -
Enhance Existing Hardware
The network adapter card connects to an available M.2 2280 PCIe slot (B or M key compatible). Standard and low-profile brackets and a 2ft (60cm) Cat6 adapter cable are included for versatile installation. Compatible with Windows, VMware, and Linux. -
Advanced Features
This Ethernet card supports the following advanced features: PXE Boot, Wake-on-Lan (WoL), VLAN tagging, 9K jumbo frame, half-duplex, auto-negotiation, and Error Correcting Memory (ECC) for optimal network functionality.
- StarTech.com 1-Port 2.5GbE M.2 Network Card, Multi-Gigabit Speeds (2.5G/1G/100M/10M) - NBASE-T (802.3bz), PCIe Ethernet M.2 2280, B/M Key - NIC for SFFs/Desktop PCs, Includes 2ft Cat6 adapter, Full/Low Brackets (MR12GI-NETWORK-CARD) - network adapter - M.2 2280 (B+M Key) - 10/100/1000/2500Base-T x 1 - TAA Compliant
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Specification Revision
- PCIe 2.0
- Ports
- 1.5 cm x 2.2 cm x 8 cm
- 15 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
- Data Transfer Rate
- 2.5 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- 1 x Intel I225-V
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3bz, IEEE P802.3az, IEEE 1588v1
- Red
- System Requirements
- Microsoft Windows Server 2019, VMware ESXi 7.0, Microsoft Windows Server 2022, Microsoft Windows 10 / 11, Linux 5.8.x or later (LTS versions only)
- TAA Compliant
- 2-year warranty
- Network adapter
- Form Factor
- PCIe 2.0
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2.5 Gbps
- Capacity
- Status Indicators
- Link/activity/speed
- Auto-negotiation, VLAN support, WOL, half duplex mode, full duplex mode, QoS, PTP, EEE, VLAN Tagging, AVB, promiscuous mode, Intel vPro Technology support, Auto MDIX, PXE boot, ECC memory, bus powered
Processor / Memory
- Processor
- 1 x Intel I225-V
- 1 x 10/100/1000/2500Base-T - RJ-45
- Included Accessories
- Low-profile bracket, full-height bracket, M3x2 screw
- Cables Included
- 1 x CAT6 adapter cable (external)
- WEEE, Cat5e, CAT 6
- Red
- TAA Compliant
- OS Required
- 1.5 cm
- 2.2 cm
- 8 cm
- 15 g
- Shipping Width
- 3 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 14.2 cm
- Shipping Weight
- 170 g
- Limited warranty - 2 years
