StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M
Quicklinx: 7B80WS00 Mfr#: USB3SAB1
Connect to your external solutions and transfer data at 10x the speed of USB 2.0. StarTech.com's 1-foot USB 3.0 cable (A-B, male-male) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, the 1-foot USB 3.0 cable supports a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 1-foot USB 3.0 cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
StarTech.com 1 ft / 30cm SuperSpeed USB 3.0 Cable A to B - USB 3 A (m) to USB 3 B (m) (USB3SAB1) - USB cable - USB Type A to USB Type B - 30.5 cm
USB cable
Shielded twisted pair (STP)
5 Gbps data rate
Length
30.5 cm
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type B - male
USB 3.0
Blue
P/N: 35BAYUSB3S4, ECUSB3S22, FCREADHCU3, S3510BMU33, S3510SMU33, S351BU313, S3520BU33ER, S352BU313R, S352BU33HR, S3540BU33E, S355BU33ERM, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, ST4300U3C3, ST7300USB3B
USB cable
American Wire Gauge (AWG)
28
5 Gbps data rate
Length
30.5 cm
Blue
Connector
USB 3.0, RoHS
7B80 StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £40.55
7B80 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £28.42
