Easily duplicate one USB 2.0 Flash Drive to two Flash Drives simultaneously or Erase USB Flash Drives, without connecting to a computer. The USBDUP12 Standalone Flash Drive Duplicator/Eraser offers a quick and easy solution for cloning a USB flash drive to one or two target USB flash drives or erasing up to two thumb drives simultaneously without having to connect the drives to a computer system.
Featuring high performance duplications at up to 1.5GB per minute, the flash drive copier has a lightweight design and user friendly interface that includes an integrated LCD display. The duplicator can copy the entire source drive volume, or for quicker backups just the data on the drive.
In addition, the target USB ports of the duplicator also support connecting to external USB storage devices. The standalone USB duplicator supports copying/cloning to SD/ SDHC/ Micro SD/ MMC/ Mini SD/ CF media through a USB multimedia card reader (sold separately), and to Hard Drives or Solid State Drives through a Hard Drive docking station or USB enclosure.
The Drive Duplicator also functions as a Flash Drive Eraser capable of erasing up to two USB drives simultaneously with several erase modes available including Quick erase and Full erase, as well as Secure erase, which follows the USA Department of Defense (DoD) secure erase standard, passing over the flash drive 3 times to ensure that the data has been completely wiped.
1:2 Drive Duplication
The USB cloner lets you copy up to two drives simultaneously (synchronous duplication) with speeds of up to 1.5GB per minute. It also offers asynchronous duplication which lets you remove and replace a drive while the other drive continues to copy. The duplicator features two duplication modes: system-and-file, or whole-drive. System and file provides reduced duplication times, copying partitions and stored data while ignoring any sections with empty space. Whole-drive provides a sector-by-sector (mirror image) duplication of the drive. This duplication mode is ideal when you need to capture everything on the drive, including hidden data. -
Erase Two Drives Simultaneously
The USB flash drive duplicator lets you wipe USB drives two at a time and supports several erase modes including: • Quick erase • Full erase • Secure erase Secure erase meets global requirements, including the new NIST (SP 800-88 Rev1) standards, ensuring that all drives are wiped properly. -
Easy to Use
The standalone USB duplicator features an LCD display so that you can monitor erasing and duplication to ensure completion. It also has four shortcut keys for easy operation. USBDUP12 is TAA compliant and backed by a StarTech.com 2-year warranty with free lifetime technical support.
- StarTech.com 1:2 Standalone USB Duplicator and Eraser - Memory Stick Cloner - USB 2.0 Flash Drive Copier / Thumb Eraser (USBDUP12) - USB drive duplicator
- Black
- Installed Devices / Modules Qty
- 2 (max)
- Localisation
- North America, United Kingdom, Europe
- Built-in Devices
- Status LCD
- Hard Drive
- No HDD
- Power
- AC 120/230 V
- 13 cm x 12 cm x 2.5 cm
- 190 g
- 2-year warranty
- Designed For
- P/N: SVA5H2NEUA
- Enclosure Colour
- Black
- Localisation
Chassis
- Built-in Devices
- Status LCD
- Supported Devices / Modules Qty
- 2
Hard Drive
- No HDD
- 3 x USB 2.0 - 4 pin USB Type A
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 13 cm
- 12 cm
- 2.5 cm
- 190 g
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 5 - 95%
- Designed For
- P/N: SVA5H2NEUA
StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser | In Stock | £482.91 |
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library | In Stock | £269.26 |
StarTech.com SATA/SAS Duplicator & Eraser | In Stock | £1,128.94 |
StarTech.com StarTech.com Hard Drive Eraser | In Stock | £559.63 |
StarTech.com USB Duplicator and Eraser 1:15 | In Stock | £1,147.98 |
StarTech.com USB Duplicator and Eraser 1:7 | In Stock | £663.80 |
StarTech.com M.2 SATA & M.2 NVMe Duplicator | In Stock | £681.14 |
