Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B printer cable lets you connect your USB 2.0 peripheral devices, such as a portable printer or scanner, or an external drive to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
The non-standard 0.5-meter cable is great for close-range connections. It lets you set up in small offsite workspaces, or in a coffee shop or hotel room, so that you can install your equipment without excess cable getting in your way.
- StarTech.com USB C to USB B Printer Cable - 1.6 ft / 0.5m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB2CB50CM) - USB-C cable - 24 pin USB-C to USB Type B - 50 cm
- USB-C cable
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type B - male
- Thunderbolt 3 / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Length
- 50 cm
- Black
- 28 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS, WEEE
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £16.47 |
StarTech.com 2m 6ft USB 2.0 C to B Cable | In Stock | £15.10 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £15.16 |
StarTech.com 3m USB 2.0 C to B Cable | In Stock | £19.57 |
StarTech.com 0.5m USB 2.0 C to B Cable | In Stock | £11.26 |
