This 15 ft Coax VGA Monitor Cable is designed to provide the highest VGA video quality possible. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables and provides superior EMI interference protection by using ferrite cores near the connector ends. This 15ft cable is a reliable solution for any high-res VGA application.
- StarTech.com 15 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 4.6 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Ferrite bead
- Length
- 4.6 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- UL 2919, NEC-CMG
- Black
- Limited lifetime warranty
- Designed For
- P/N: BOX4CABLE, BOX4HDECP2, CDP2DPVGA, CDP2HDVGA, CDP2VGASA, CDP2VGAUCPW, DK30BACDD, DKT30CVAGPD, IPUSB2VGA2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, MDPVGDVHD4K, MOD4AVHD, MOD4AVHDBT, PEXHDCAP2, PEXHDCAP60L2, ST121HDBTSC, STDHVHDBT, SV231DVGAU2A, USB32VGCAPRO, USBC2VGCAPRO, VID2VGATV3, WIFI2HDVGA
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Ferrite bead
- Length
- 4.6 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- UL 2919, NEC-CMG
- Designed For
- P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, CAB1631HD, CAB831HD, CAB831HDU, CABCONS1716I, CDP2DPVGA, CDP2HDVGA, CDP2VGASA, CDP2VGAUCPW, CPNT2VGAA, DK30BACDD, DKT30CVAGPD, DP2HDVGA, DP2VGAAMM2M, DP2VGAAMM3M, DS154, DVI2VGACON, HD2VGAMICRA, HDMI2VGA, IPUSB2VGA2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, MCHD2VGA, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, MOD4AVHD, MOD4AVHDBT, PEXHDCAP2, PEXHDCAP60L2, RACKCONS1916, SLMPT2VGA, ST1212T, ST1214T, ST1216PRO, ST1218T, ST121EXT, ST121HDBTSC, ST121R, ST121UTP, ST121UTP232, ST121UTPEP, ST122LE, ST122LEA, ST122PRO, ST122PROA, ST122UTPA, ST122UTPAL, ST122VGA, ST122VGAU, ST122W, ST124PRO, ST124UTPEA, ST124W, ST128PRO, ST222MX, ST222MXA, ST224MX, ST424MX, STDHVHDBT, STUTPEALR, STUTPWALLA, SV231DVGAU2A, SV231USBDDM, SV431DVGAU2A, SV431USBDDM, SV565DUTPU, SV565UTP, SV565UTPU, SV565UTPUL, USB32VGAEH, USB32VGAV, USB32VGCAPRO, USB3SDOCKDD, USBC2VGCAPRO, VGA2HD2, VGA2HDPRO2, VID2VGATV, VID2VGATV2, VID2VGATV3, VS221HD2VGA, VS221VGA2HD, VS410RVGAA, VS721MULTI, WIFI2HDVGA
