Sony Uni-Directional Hand Held Microphone
Quicklinx: 4GFPWS00 Mfr#: FV220.CE7
The High quality vocal microphone FV220 features convenient all-in-one unimatch plug, built-in On/Off switch and neodymium magnet for extended frequency response to reproduce dynamic sound.
  • Superior audio clarity
    The Sony FV 220 microphone is designed with a frequency response of 100 - 12000 Hz and an impedance of 600 ohm, ensuring clear and detailed sound reproduction for professional audio applications.
  • Durable design
    Featuring an integrated 3 m microphone cable and a robust form factor, this microphone is built to withstand the rigors of daily use in any professional setting.
  • Versatile connectivity
    Equipped with a mini-phone mono 3.5 mm connector, the Sony FV 220 offers flexible connectivity options, making it compatible with a wide range of audio equipment.
Sony FV-220 - microphone
Microphone
Recommended Use
Professional audio - vocal
Microphone
External
Microphone Technology
Dynamic
Microphone Operation Mode
Mono
Controls
On/off
Microphone
21.1 cm
Diameter
5.4 cm
215 g
Recommended Use
Microphone
Dynamic
Mono
Wired
Impedance
600 Ohm
Frequency Response
100 - 12000 Hz
Audio Input Details
Uni-directional - 100 - 12000 Hz - Effective Output Level -53 dB - Output Impedance 600 Ohm
Remote Control
Controls
On/off
Connector Type
Microphone (mini-phone mono 3.5 mm)
6.3 mm (1/4") stereo adapter
Cable Details
Microphone cable - 3 m
