Efficient audio input
The Sony TCM-939 comes equipped with a built-in microphone, designed for mono operation, ensuring clear audio capture for all your dictation and transcription needs. -
High-quality sound
Featuring a frequency response of 150 - 8000 Hz, this cassette recorder delivers consistent, high-quality sound output in mono, making it ideal for both personal and professional use. -
Versatile cassette system
With mechanical control type, cue and review controls, and a handy tape counter, the cassette system in the TCM-939 is built for ease of use and reliability. -
Convenient power options
Operable with AA type standard batteries or an external power adapter, the Sony TCM-939 offers flexible power solutions to suit your recording situations. -
Integrated speaker system
This model includes a built-in speaker with a 2.6" full-range driver, providing clear playback without the need for external speakers.
- Sony TCM-939 - cassette recorder
- Product Type
- Cassette recorder
- 14.4 cm x 23.7 cm x 6 cm
- 0.75 kg
- Sound Output Mode
- Mono
- Audio Specifications
- Cassette - response bandwidth: 150 - 8000 Hz
- Cassette System
- Mechanical
- Speakers
- 1 x speaker - built-in - 0.4 Watt - 150 - 8000 Hz
- Microphone
- Microphone - built-in - mono
- Battery
- 4 x AA type
- Product Type
- Cassette recorder
Audio System
- Sound Output Mode
- Mono
- Functions
- Cassette dictaphone/transcriber
- Cassette - response time: 150 - 8000 Hz
- Record Level Control
- Automatic
Speaker System
- Speakers
- 1 x speaker - built-in - 0.4 Watt - 150 - 8000 Hz - 8 Ohm
- Driver Details
- Speaker: 1 x full-range driver - 2.6"
Cassette System
- Control Type
- Mechanical
- Tape Counter
- Cue and review controls
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- DC power input
- Power Device
- Power adapter - external
- Battery
- 4 x AA type
- Run Time (Up To)
- 9 hour(s)
- 14.4 cm
- 23.7 cm
- 6 cm
- 0.75 kg
Sony TCM-939 - Cassette recorder
