Transform your meetings with the SMART Room System for Microsoft Lync. An integrated, turn-key hardware solution, it combines SMART's industry leading interactive displays with Microsoft Lync to enable rich audio, video and data collaboration. This helps engage every meeting participant by enabling them to contribute ideas in more creative ways and provides them with a more inspired way to collaborate.
Leveraging Microsoft Lync
Enhance your investment in Microsoft Lync by expanding it into the meeting room. You will not need to invest in conflicting infrastructure and your users will be able to work within a familiar user interface. -
More effective collaboration
Evolve from traditional videoconferencing to fully immersive collaborative meetings by enabling comprehensive data interaction. Participants can be seen and heard, but are also able interact with the content being discussed. This ensures that they stay engaged and are able to fully contribute to the conversation. -
Intuitive interaction
The familiar, inviting design of SMART's interactive displays encourages use by making interaction with digital content a natural experience. You can use your finger to interact with content, pick up a pen and write over it in your choice of color and use your palm to erase. -
An integrated solution
All of the room components are designed to work together. This creates a single integrated solution for audio, video and data collaboration that simplifies installation, support and ensures the components function as a single system. -
Systems designed for any room
SMART offers small, medium, and large systems for rooms designed for 2 to 16 people and ranging from 100 to 300 square feet. -
Proximity detection
The SMART display will automatically turn on when it detects motion in the room. This saves energy costs when not in use and allows quick access to the technology when meetings start. -
Wide angle camera
SMART's camera features a 109 degree field of view allowing remote users to see the entire room without the need for pan/tilt/zoom functionality. -
Natural videoconferencing
SMART's camera reduces eye gaze, making remote and in-room participants feel as though they are looking each other in the eye. -
Object awareness
The SMART display automatically detects a finger or a pen without special mode switches or buttons and allows users to erase ink on the display with their palm. -
Administrative console
The large 11" room control lets users change the screen layout, display presentation content and email notes at the end of the meeting. -
Microsoft Lync interface
Users who know Microsoft Lync will find it easy and intuitive to use the SMART Room System. It maintains the Microsoft Lync interface they are familiar with. -
Support for scheduled or ad hoc meetings
The SMART Room System supports the ability to start ad hoc whiteboarding sessions or to set up scheduled meetings. Either meeting starts with just the touch of a button.
- SMART Room System for Microsoft Lync for medium rooms with dual panels - video conferencing kit
- Video conferencing kit
- Display
- 54.6" 1920 x 1080
- Number Of Screens
- 2
- Video Input
- Digital camera
- Audio Input
- Two microphones
- Audio Output
- Speaker(s)
- Input Device
- Console
- Power
- AC 120/230 V (50/60 Hz)
- 2-year warranty
Display
- Number Of Screens
- 2
- Diagonal Size
- 54.6"
- Native Resolution
- 1920 x 1080
- Image Aspect Ratio
- 16:9
- Image Brightness
- 290 cd/m²
- Image Contrast Ratio
- 2800:1
- Monitor Features
- Touch screen
Video Input
- Digital camera
- Digital Video Capture Resolution
- 1920 x 1080
Audio Input
- Two microphones - desktop
Audio Output
- Speaker(s)
Input Device
- Console
- UL, VCCI, CB, IC, FCC, RoHS, WEEE, PSE Mark, REACH
- Voltage Required
- 540 Watt
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 10 - 80%
