Sennheiser SC 60 USB Binaural UC Headset with Call Control
Quicklinx: 8RRDWS00 Mfr#: 504549
SC 60 USB CTRL is a deployment-friendly, dual-sided headset. Features include noise-canceling microphone and large comfortable ear pads. SC 60 USB CTRL is designed for users requiring Sennheiser stereo sound and call control when working in a unified communications environment.
  • Focus fully on the conversation
    If you work in a busy office, you'll appreciate the voice clarity in the Culture Series headsets. With a noise-canceling microphone and wideband sound, every word comes through crisp and clear for you and the other party. It's as if you're having a face-to-face conversation.
  • Plug and play experience
    If you're moving towards a solution that brings together all the communication tools in your office, the Sennheiser Culture Series headsets will help make the transition smooth. Culture headsets offer plug and play compatibility with the leading Unified Communications solutions. This ensures that your office workers can enjoy voice clarity, quality sound and comfort right from the start.
  • Comfort and durability
    With large, comfortable ear pads and solid construction, you'll be surprised at how light these headsets feel. It's the perfect balance between comfort and durability for the office professional.
Sennheiser Culture SC 60 USB CTRL - headset
Headset - wired
Recommended Use
Computer - communication
Black with blue colour highlights
Headphones Form Factor
On-ear binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 60 - 16000 Hz
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Headset - wired
106 g
Recommended Use
Audio Output
On-ear binaural
Wired
Sound Output Mode
Stereo
Frequency Response
60 - 16000 Hz
Max Sound Pressure
113 dB
Magnet Material
Neodymium
Adjustable Headband
Microphone
Boom
Frequency Response
150 - 6800 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Foam ear pads
Cable Details
USB cable - 2.1 m
International warranty - 2 years
Shipping Width
17 cm
Shipping Depth
6 cm
Shipping Height
24 cm
