The ideal headset for all your Internet telephony needs. The PC 36 Call Control delivers great voice clarity for every conversation. Thanks to Sennheiser stereo sound, the PC 36 Call Control also lets you enjoy music, movies and games. The 3-in-1 unit lets you quickly adjust settings, such as the volume or mute. And control all calls - take and end conversations directly on the headset.
Because PC 36 Call Control has its own USB soundcard built-in, there's no need for an external adapter. What's more, the fully flexible boom arm lets you position it exactly where it needs to be for talking, or moved out of the way for enjoying your multimedia fun.
Sennheiser sound
The integrated USB soundcard and quality speakers ensure every word comes through crystal clear. -
Noise canceling clarity
Not only will your voice come through in crystal-clear quality, the microphone is also ideal for your device's speech recognition function. -
USB Plug and Play
Simply plug into your computer's USB port to start phoning over the net. -
Convenient 3-in-1 control
Fully adjust the volume/mute and control your phoning session directly from the headset. -
Comfortable double-sided headband
It is ideal for an entire range of multimedia applications such as music and gaming, too. -
Fully flexible boom arm
Adjust the microphone for optimal voice pick-up and comfort. -
Light and comfortable
With the lightweight headband, it's easy to forget you are even wearing a headset.
- Sennheiser PC 36 Call Control - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 40 - 18000 Hz - Sensitivity 109 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Controls
- Volume
- 2-year warranty
- Product Type
- Headset - wired
- 100 g
- Recommended Use
- Computer
- Packaging Type
- Blister
Audio Output
- On-ear binaural
- Wired
- Sound Output Mode
- Stereo
- 40 - 18000 Hz
- Sensitivity
- 109 dB
- Impedance
- 32 Ohm
- In-Cord Volume Control
Microphone
- Boom
- Sensitivity
- -38 dBV/Pascal
- Impedance
- 2 kOhm
- 80 - 15000 Hz
Remote Control
- Controls
- Volume
- Connector Type
- USB
- Plug and Play
- International warranty - 2 years
