Your basket is empty
Seagate Cheetah 15K.5 300GB U320 16MB 3.5" 80PIN 15KRPM
Quicklinx: 4F5TWS00 Mfr#: ST3300655LC
Seventh-generation Seagate Cheetah 15K.7 drive is the fastest, highest capacity and most reliable ever. Lower watts/GB ratio helps achieve reduced power and cooling costs while optimizing capacity requirements. Seagate continues to focus on reliability and data protection. MTBF is an industry-leading 1.6 million hours. Seagate-exclusive enhanced error correction code better maintains performance throughout the life of the drive and reduces the probability of lost data. The third generation of Seagate-exclusive background media scan proactively scans the media for potential defects during drive idle time. It enables incipient errors to be corrected before data is lost. Quick and robust download feature loads firmware in seconds, with built-in protection to ensure no corruption in the event of a power failure during firmware switch.
Seagate Cheetah 15K ST3300655LC - hard drive - 300 GB - Ultra320 SCSI
Hard drive - internal
300 GB
3.5" x 1/3H
Ultra320 SCSI LVD
Connector
80 pin Centronics (SCA-2)
Data Transfer Rate
320 MBps
Buffer Size
16 MB
Spindle Speed
15000 rpm
Perpendicular Recording, Idle Read After Write (IRAW), Enhanced Error Correction Code, Background Media Scan (BMS), S.M.A.R.T.
10.2 cm x 14.6 cm x 2.6 cm
0.84 kg
Microsoft Certification
Works with Windows Vista
5 years warranty
300 GB
3.5" x 1/3H
Ultra320 SCSI
Connector
SCSI Signalling Type
Low Voltage Differential (LVD)
Buffer Size
16 MB
10.2 cm
14.6 cm
2.6 cm
0.84 kg
Performance
Drive Transfer Rate
320 MBps (external)
Internal Data Rate
150 MBps
Seek Time
3.5 ms (average) / 6.7 ms (max)
Track-to-Track Seek Time
0.2 ms
Average Latency
2 ms
Spindle Speed
15000 rpm
Reliability
Recoverable Errors
10 per 10^12
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x Ultra320 SCSI - 80 pin Centronics (SCA-2)
Compatible Bay
3.5" x 1/3H
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
5 years warranty
Limited warranty - 5 years
5 °C
50 °C
0 - 95%
Shock Tolerance
60 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Vibration Tolerance
1 g @ 5-400 Hz (operating) / 2 g @ 5-400 Hz (non-operating)
