Backup Plus Fast Portable Drive: Fast HDD Portable Drive
1,583 Movies. One Drive. With up to 2x the capacity and speed of other portable hard drives.
Seagate Backup Plus Fast, the world's first 4TB high-performance portable hard drive
The Seagate® Backup Plus Fast portable drive offers up to 2× the capacity and performance compared to other portable drives. The drive is fully USB powered and does not require an external power supply, allowing you to take up to 4TB of videos, music and pictures with you on-the-go. Take further advantage of the fast USB 3.0 interface with transfer speeds up to 220MB/s. The included Seagate Dashboard provides scheduled and automatic backup options for your computer, social networks and even your mobile device. Install the free Seagate Mobile Backup app on an iOS or Android mobile device to back up all of the pictures and videos from the device to the drive or the cloud. Back up mobile devices via a WiFi connection while at home, or use services like Dropbox or Google Drive™ while on-the-go, away from home. The metal design fits easily in a computer bag or backpack, and helps resist against scratches and fingerprints during transport. For the first time, users can store as much data as a 3.5-inch desktop drive in a portable drive. Use the Save and Share features to download and upload content from your social network sites like Facebook and Flickr. Even photos you are tagged in can now be backed up to the drive. Install the pre-loaded NTFS driver on a Mac® computer, and use the drive between Windows® and Mac computers without having to reformat the drive.
Capacity and Speed
The Seagate® Backup Plus Fast Portable Drive performs at up to 2× the speed of other portable hard drives.
- The highest capacity, 2.5-inch portable hard drive on the market
- USB 3.0-powered: no bulky external power supply needed
- Sleek, tough, metal design for everywhere portability
- Share files between Windows® and Mac® computers, no reformatting necessary
Your Entire Digital Library -- On Just One Drive
Your data is more essential than ever: movies, music, photos, professional projects and more. The Backup Plus Fast Portable Drive has the highest capacity of any 2.5-inch portable drive on the market, so you can take your entire digital library with you -- wherever.
Fast HDD Portable Drive: Up to 2× the Speed of Other Portable Hard Drives
The Backup Plus Fast Portable Drive delivers some of the fastest data transfer speeds -- up to 220MB/s -- of any 2.5-inch portable hard drive out there. In fact, it is actually up 2× faster than most, so you can spend less time waiting and more time enjoying.
Back Up From Your Mobile Devices
Use the Seagate Mobile Backup app to easily back up photos and videos on the go, directly from your mobile devices to your Backup Plus Fast Portable Drive.
Fast HDD Portable Drive: Easy Backup With Seagate Dashboard
Choose from two easy, automatic backup options in the Seagate Dashboard -- scheduled or continuous backup -- and be done.
What's Included?
- 4TB Backup Plus Fast Portable Drive
- Seagate Dashboard preloaded on drive
- 18 inch (45cm) USB 3.0 cable
- USB 3.0 Y-cable
- Quick start guide
- 3-year limited warranty
Your entire digital library - on just one drive
Your data is more essential than ever: movies, music, photos, professional projects and more. The Backup Plus Fast portable drive has the highest capacity of any 2.5-inch portable drive on the market, so you can take your entire digital library with you - wherever. -
Up to 2x the speed of other portable hard drives
The Backup Plus Fast portable drive delivers some of the fastest data transfer speeds - up to 220 Mbps - of any 2.5-inch portable hard drive out there. In fact, it is actually up 2x faster than most, so you can spend less time waiting and more time enjoying.
- Seagate Backup Plus Fast STDA4000200 - hard drive - 4 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 4 TB
- Interface
- USB 3.0
- Automatic backup
- Enclosure Colour
- Black
- 82.5 mm x 22.35 mm x 116.9 mm
- 307 g
- Localisation
- Middle East, Africa, Europe
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 4 TB
- Interface
- USB 3.0
- Automatic backup
- 82.5 mm
- 22.35 mm
- 116.9 mm
- 307 g
Expansion & Connectivity
- 1 x USB 3.0
- Software Included
- Seagate Dashboard
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
- Cables Included
- 1 x USB 3.0 cable - external - 91.44 cm
- Enclosure Colour
- Black
- Localisation
- Limited warranty - 3 years
