The Seagate Expansion external hard drive by Seagate offers an easy-to-use solution when you need to add data storage to your computer instantly.
- Instantly add 2 TB of storage space to your computer
- Simple plug-and-play connectivity via USB cable
- USB powered, no AC adapter required
- USB 3.0 interface for extremely fast data transfer speeds (USB 2.0 compatible)
- Drive is automatically recognized by Windows; no software installation required
The easy-to-use storage solution
The Expansion external hard drive can be installed easily by plugging in two cords. You can start saving your digital files to this hard drive within seconds of removing it from the box. -
Adds storage capacity instantly
Digital photos, video and music files can tax your computer's storage, causing performance to decline as its internal hard drive fills to capacity. The Expansion external hard drive helps remedy this situation by enabling you to free up storage space on your computer's hard drive.
- Seagate Expansion Desktop STBX2000401 - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Power Source
- USB bus
- 81.1 mm x 15.5 mm x 122.3 mm
- 170 g
- Localisation
- Worldwide
- 1-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 81.1 mm
- 15.5 mm
- 122.3 mm
- 170 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- OS Required
- Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
- Cables Included
- 1 x USB 3.0 cable - 45.72 cm
- Localisation
- Worldwide
- Limited warranty - 1 year
