Upgrade your on-the-go setup with the Satechi Slim X1 Bluetooth Backlit Keyboard. Designed with Apple users in mind, the keyboard features a full QWERTY layout, multi-device Bluetooth connection, and macOS function keys - all with a smaller, more compact size. Perfect for setting up in your home office or at an outdoor café, the Slim X1 Bluetooth Backlit Keyboard is equipped with convenient backlit keys and a rechargeable USB-C port for enhanced typing in any setting.
Designed for Apple users in mind
Connects up to three Bluetooth devices
Illuminated keys & USB-C rechargeable
Ultra-compact, sleek design
All the features you love
Designed with Apple users in mind, the Satechi Slim X1 Bluetooth Backlit Keyboard includes all the must-have features you need, like easy-to-use Bluetooth, adjustable backlit keys, and Mac function keys - all with the bulkiness you can leave at home. -
Convenience at your fingertips
Featuring backlit illuminated keys with ten adjustable brightness levels, plus function hot keys designed for Mac & iOS to work with ease wherever you are. -
Multi-device Bluetooth
Equipped with Bluetooth keys to effortlessly type across up to three connected devices, so you can go from writing out an email to texting back the group chat with a single press of a button.
- Satechi Slim X1 - keyboard - QWERTY - UK - space grey
- Keyboard
- Backlit
- Interface
- Bluetooth 3.0, USB-C
- Connectivity Technology
- Wireless, wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Application switching, search, mute, brightness, play/pause, previous track, next track, backlight control, volume -, volume +, Fn key lock, eject
- Space grey
- 28.3 cm x 11.4 cm x 0.99 cm
- 295 g
- 1-year warranty
- Keyboard
- Backlit
- Interface
Input Device
- Wireless
- Hot Keys Function
- QWERTY UK
- Detachable Cable
- 28.3 cm
- 11.4 cm
- 0.99 cm
- 295 g
- Space grey
- Included Accessories
- USB-C charging cable
- OS Required
- Apple MacOS, Apple iOS
- Limited warranty - 1 year
